ssian
What is the difference between a Viper reverse kit and a VMAX reverse kit?
thanks ian
thanks ian
ssian
anyone?
the chain used, the sxr uses the 13 wide std chain, the viper uses the hyvo chain, the tooth is more rounded to make it quieter and is supposed to be stronger then the std chain.
ssian
reverse
so i should still be able to use it on my sxr?
you could use it in either sled as long as its used as a complete unit with chain.
mrviper700 said:you could use it in either sled as long as its used as a complete unit with chain.
Are we talking internal parts only or is the case and cover a direct bolt on as well?
