snowprophet1
If I wanted to put viper 700 cylinders on a srx 700, would I only have to machine in the grooves for the o-ring gaskets to use my heads? I know the exhaust valves are different part #'s but are they interchangable, or should each stay with it's own original type cylinder? Exhaust manifolds work? Any other things to worry about? Thanks!
AtlasFBG2
You could use a head gasket and have the heads cut the thickness of the gasket instead of haveing the cylinders machined for the o rings.
SRXSRULE
- May 2, 2003
The exhaust manifolds will not bolt up and the valevs are NOT interchangable!!!!!! Dont try it. ===SRXSRULE===
snowprophet1
Thanks guys!
Kgmz
Here is a cross section of the Viper and SRX cylinders, so you can see why the exhaust manifold won't fit, etc.
snowprophet1
Great picture! Thanks!
