2004 Viper ER Power valves
pvggreenville
Greenville, Wisconsin
Is the procedure to adjust the power valves the same as non battery equiped Vipers? I adjusted idle to below 900 rpms but servo motor did not move. It does cycle every time the ignition key and kill switch are in the run position.
Set your idle back to stock. This is the procedure for non-battery equiped machines. When you turn your key on the servo will go to the right position. Start your adjustment from there.
