wireing heated visor on to sled
Swuff
Barrie, On
Hey guys,
I have 2 thoughts as to where to connect the wires.
First- would it be okay to take the screws out of the coil then put the screws back in?
Or,
There is what looks like an aux. plug hanging just to the left of the carbs (if you were looking t the sled.) It has the female part with it and found 3 little rubber plugs, that were inserted where wires were supposed to be. If this is the best spot to wire up to, what would be the name of the the metal clips that I would crimp onto the wires?
+ In this port would there be enough volts to keep me from fogging up?
so in other words leave that aux port alone, and go thru the handle bars? what would this port be for?
