Works Shocks typical recharge interval?
I dont know for sure, but the basic type of shock that a works is should last longer than a regular shock, becusa there is no need to keep the ooil and nitro seperate
I was thinking along the exact same lines. This was one reason I went with that type of shock. I did recieve a little note from Works which basically said "check the valve cores are tight. charge to 250 psi nitrogen. Prime valve with oil. service is not needed" . I had them charged to 250 psi and called it good. thanks for your reply
Doc
Doc
