srx oil pump question
turbor
mirabel,qc
I'm sure i have read somewhere that when you're 75% throttle the oil pump is already maxed out 100% but can't find it anymore can anyone confirm this?
I dont know for sure to answer that but you can adjust how far you pull it, shorten up the slack and it will pull it further. I assume its with the mach z carbs?
yes its with the mach z carbs, and to adjust it, i did exactly the way you just described ;)! But i really dont like the idea of having it poor to mutch oil in it for nothing, it leans out the mixture also and gums everything. thats why the 75% is so important for me to find out!
the differance in the 25% pull wouldnt be flooding it with oil, your using good oil anyways and with a 780 good oil and plenty is a good thing, youll be fine.
