shock set up
progold
bathurst new brunswick
Well tightened up my rear suspension and when i disassembled it the previous owner had the rear center shock(the big one) wound up pretty tight ,i weigh 185 lbs and was wonderig what the setting would be for someone of my weight,i dont jump the sled just do some agressive trail riding any info would be great.
PROGOLD
the gap on your transfer rods should be equal top and bottom with you on it. Also set the FRA to full sof for this adjustment and your front shock should have just enough tension to keep the spring from flopping around.
the owners manual actual explains the sag and set up pretty well if you have one. otherwise you can view them at yamaha-motor.com
