1.25 track or 1''
yamaviperGS30
If you want studs should you change the drivers on a ripsaw, or should you just put a 1'' 9830 and then stud? How long of studs can you put on with 02 viper with ripsaw and diff. drivers. Would really like the ripsaw but deffinitely need studs.
No studs...
i have an 02 viper, put on an 1.25 camo, no studs, and she hooks up great, only time i have wanted studs is on the occaisional grip and rip down the ice/backroad, and stopping on ice, otherwise, havent missed studs at all.... way better hook than with the stock track.
I have 2 2003 Viper ER's. One I put a 136" x 1.25 ripsaw on, and changed to 8 tooth drivers, changed the gearing as well. I may or may not stud it, but changed drivers just in case.
If you're wanting a brand new take off camo 9815 I think, I have it somewhere in my shed. ZERO miles on it. Make offer
It's the stock 2003 Viper track. It's a camo 1" cone track. It hooks up pretty good on my stock 2003 Viper. I think it has every third window closed.
It's a 9855H track #
Thanks for the reply,wasn't sure about the #'s that is the track I'm trying to replace,In my opinion it isn't worth #@$% unless on the hard packed.
1.325 stud size on ripsaw, as per woody's traction control system for 5/16 studs. This info found on page 76 &77 of snow tech sept 04. Track can be ordered with predrilled holes with a warranty.
