Cwagner100
I have an 83 vmax 540 and i heard that the carberators were different from side to side jetting wise. I was wondering if this is true and if it is what jets should be on each side?
Also can you mix and match cylinders from different years of the vmax 540?
Vmax540
YAMMIEGOD3:16
SECOND QUESTION IS YES AND FIRST QUESTION IS STANDARD MAIN JET WAS A 330 WITH A 45 pilot. NOW OPTIONAL MAIN JETS VARY FROM A #200 UP TO A #350. IF YA NEED EXACT CARB SPEC I HAVE THEM. 3:16 (yammie tony)
Cwagner100
Sorry about the late reaction but if your could email me the exact carb specs for each carb id really appreciate it. Im restoring this sled and im getting down to the end as fare as completing it.
YAMMIEGOD3:16
E MAIL ME AT ramsr1@aol.com 3:16 (yammie tony)
Vmax540
From http://www.vintagevmax.com/ 1986 Spec's.
Carburetor- Mfr.- Type/ Size/ Qty/ ID Number Mikuni- VM38/ 38mm/ 2/ L:80N-00 R:80N-00
Main Jet/ Main Air Jet 290/ 2.5
Air Screw 1.5
Pilot Jet/ Pilot Screw (Turns Out) 40/ �
Needle Jet/ Jet Needle- Clip Position/ Cut Away/ Air Jet Q-0/ 6DH1-4/ 3.0/ �
Power Jet/ Power Air Jet L:135 R:130/ L:1.5 R:1.4
Fuel Inlet Valve/ Float Level 1.5/ 18.1mm
Idle Speed 1500 rpm
Air Screw 1.5
Idle Speed 1500 rpm
