how much side to side play should there be on the secondary clutch of my 2000 sx-r 600 and also if im going slow (5-10 km) and hit the breaks hard there its a clunk sound comeing from the secondary wat could this be?
mopar1rules
is the track off the ground (back of sled supported by stand) when you are hitting the brakes hard and hearing the clunk? side to side play i think is around .080".
Have you checked your drive chain tension? Too loose condition could be what your seeing as excessive play in the secondary and a direct result is the noise you hear when you lock up the brakes.
i checked my chain tention but im not a 100% on wat it should be cause ive got a few diffrent ansers on how to tightin it but how do u guys sugest i do it ( ps sorry for the spelling mistakes)
Tight
The Yamaha repair book states to finger tighten. I just did mine that way...
wats finger tention tho like a snug as hard as you can get it or like just kinda snugg-ish
1-2mm in the secondary is the norm.speerssrx said:how much side to side play should there be on the secondary clutch of my 2000 sx-r 600 and also if im going slow (5-10 km) and hit the breaks hard there its a clunk sound comeing from the secondary wat could this be?
the clunk could be loose chain or track,finger tight on the chain adjuster
is right on..welcome
snugg-ishspeerssrx said:wats finger tention tho like a snug as hard as you can get it or like just kinda snugg-ish
woofer700
just turn it in until you feel tension on the chain, just snug in my book. Check the oil in there too, if its not been done drain it and put in new.
ok thanks everyone im gonna go check it now and maybe take it for a little ride after ill get back to you on how its goes and thanks again
