fox floats
blackford81
Edmonton
Hey im just getting ready for winter. I was thinking about fox floats for my 2000 mm 700, ekholm 156 skid, ekholm tunnel, ekholm trailing arms, triple psi pipes and stingers, v force 3 reeds, 7 " riser. i was just wondering how much of a differance they would make on my sled. Thanks
just talked to a friend tonight who has these on his M8......he is taking them off and going with a standard spring/shock combo off of a non sno-pro model because they have no rebound whatsoever, nor do they have any rebound adjustment.....seems if you are gonna go that route get the evol's but dont get the standard floats.
I've got Fox floats on my MM '01. Mostly because they save you almost 5 pounds.
Here's some pics!!!
Runs flawless! Doesn't seem to a problem with the rebound. ;)!
The seat is homebuilt. A copy of a Boss!
I've used all Yamaha OEM part to mount the shocks.
The shocks are from a Phazer MTN.
You need these adepters (yamaha OEM) to make them fit and some washers.
Part nr. 14 & 15
Art nr. 8CV-2376J-00-00 And 8CV-2377J-00-00
