Just looking for options if I wanna change and don't wanna spend dough on an m-10
thanks
Mark
00 SRX
thanks
Mark
00 SRX
no, you will need to find the dimensions from the drive axel and the bottom of the tunnel...BlueByYou on the RX site has put a cat suspension in his RX1 ...try him for more info. Or go to www.thespeedshop1.com, he is the owner.
98srx6
I believe monker has a cat skid in his sled as well.
monker
Drilling is required. I put a F-cat rear into my SX and had to fabricate my own brackets. As for measurements, after taking into account distance from the ground, distance from the top of the tunnel, distance from the drivers back, and angles from front to back, I just ended up eyeing it and making sure it was square. I do believe there is a template for putting in a zl/zr skid floating around somewhere. Try the RX site.
Snowextreme831
I have put a sxr suspension into a exciter. Ive put polaris X12 under a vmax. It can be done. Best thing to do is us cardboard and locate from center of the jackshaft. Drill new holes and bolt it in.
GOOD LUCK.
GOOD LUCK.
I wonder how well a sxr suspension would work in my srx
I put a Mtn cat skid in an srx this fall. Looks like it's going to work well. Required some drilling, but it's only 4 holes. Weighed less than the stock 121 with extenions, too.
SXR skid will bolt right in a SRX....works great....even with short travel front...did one back in 99 with ohlins on the front....but it did slow it down on top end.
