dave carpenter
i need a set of lond travel rods or ones from viper where do you buy them thanks dave
Rambunctious
not sure who sells them
but they are easy to make
you can cut some bar stock of the same diameter as the rod, drill a whole in it for the bolt, and add it to the end of the rod and reinstall bolt though it
then make some plastic washers to get the proper gaps for top and bottom
that is what i did for my srx
Ramb
Ramb
dave carpenter
so what aftermarket companys and where can you order them i guess it would be viper transfer rod i think
dave
dave
bolin22
i have a set if you wanna buy used. sent a pm also.
dave carpenter
so im still looking for aftermarket transfer rods for viper for more travel
thanks dave
thanks dave
