needs a clutch and jet set up for bender vip triple pipes for my viper!
Vector88
Labrador, CANADA
hi
i have a 04 sxviper mountain. i have a set of Bender Racing VIP Triple Pipes and i need to know a good clutch and jet set up to run these. i am at sea level and temps from -20 to -40 in the winter. here is some info below about my viper. she also has boyesen reed pedals on the stock reed cages.
2004 Yamaha SX Viper Mountain
0-2000 feet elevation
-20 to -40 temp
bender VIP Triple Pipes
primary spring - Green white Green
Rollers- 15.6 mm
Weights - 8dn-10/none&10.3
Gearing - 21/40
Helix spring - Green
secondary setting - 70 degrees
Thank you!
im going to get sets of 162.5, 165, 167.5, and 170 mains and sets of 50 and 55 pilot jets for my carbs and try to tune it my self. is it true that the mag side carb will have be jetted different with the bender triple pipes where the bender pipe goes right near the mag cylinder? if so , will that jet need to be bigger or smaller then the PTO and middle carb?
