djdarkmunk
so i posted this message when i was was new here in the wrong form i guess but all 3 of my power valve's are leaking oil out of what i was told is the drain hole on to the exhaust. what am i going to need to get or buy to fix this because i see 2 gaskets and a OIL SEAL on the diagram. my question is what am i gonna need to fix my problem. also i was sold my sled with out the foam element that goes in to the air box is this a have to have thing or is it just to keep snow out. thanks guys you allwase help me out..
mopar1rules
get a new foam piece for the airbox and you will need the 2 power valve housing gaskets, along w/the oil seal. if you have oil coming out of the drain hole on the bottom of the power valve housing, then the oil seal is leaking.
I like to replace....
to fix that leak you'll need part numbers,#20,27,31,but 20 is why your leaking, 18 can be reused.
mopar1rules
daman, lets not be reusing gaskets.....lol. they're cheap enough, and since this isn't china, lets not fix things how they would....lol.
djdarkmunk
thanks my dealer charges a bit more then the internet site's Ive seen but hey all of them parts threw him alown are only like 40 bucks but ill just pick them up from him its better to support ya local shop i think.
