TPS questions
Bob Brown
NH
Does anyone know the difference between the TPS used on the 600 twin (P/N 8CR-85885-00-00) and the TPS used on the Viper (P/N 5FL-85885-00-00)? Are they interchangable?
Bob
Does anyone know how to adjust the TPS on a 600 twin? Since this is a basically a variable resistor there must be some adjustment specs to change/advance timing at some point in RPM's. I would assume that there should be a resistance spec for 1/2 throttle and full throttle. Anyone have a manual that lists these adjustments?
TPS adjusts mid range timing by a few deg.,no control on WOT but it does need to be properly set.
i would say viper would be diff. but not sure..
'97-98 twin,
