srx frt susp
nastysrx
central square n.y
has anyone long traveled the frt susp on a srx using different /longer shocks? i got a set of rev piggy backs for dirt cheap and was wondering if it was worth the hassle?they are 4" longer ctc and have it figured out i need to make radius and steering rods2" longer on each side to keep the same shock angle.as this should make the sled sit just about level with the expert-x in the rear.anny input would be great.
I would guess you can make them fit with the longer radius rods and whatnot ..but the valving would probably be off. SRX is probably heavier than the Rev and the shocks are probably valved as such.
--Steve (O.C.)
