007redline
Will front shocks off a sx chassis fit on a 2000 sxr 600. My brother in law has a 2000 sxr 600 with the front shocks beat out of it....wondering what shocks I could replace them with...cheap..lol so obviously used shocks but what will fit ??? thanks I know the srx shocks won't fit ,,tried it...
yes to your Question but make shure they are the long ones not off a 97-98 they are only 9" the one on there are 11" you can rebuild them for a little money and they will be better than new
yup getting them rebuild/valved is cheap and they'll ride better then new
used ones..
used ones..
007redline
hey
O for some reason I didn't think they were rebuildable... I try taking them off and rebuilding them if that's the case...they are the shocks with the white springs
01sxr700
Those should be Kayaba's and rebuildable. Unless u have done this before it might be better off to take them in 4 rebuild. There is 175 psi nitrogen pressure in them. U need a special needle do discharge and recharge them. U also need to know where to set the IFP 2 get them 2 work right. It usually isn't that much 2 have them rebuilt, usually $30 > $40.
