Installing Stabilizer Bar...
ajviper
Michigan
How easy is it to install a new stabilizer bar? It appears that it requires drilling our the rivets before removing. is this it? Will the bar just pull right out after removing the rivets and plates? and as far as install of the new, should I just use any stainless steel rivet, or should I order them through Yamaha?
TIA!
Yes,you have to chisel the rivets off both sides and remove the plates,then remove the plastic spacers that cup the stabilizer bar.With a little finess you the bar will come out.I used stainless rivets on my viper with no problems.
