allyammies
Sled bogs till about 5,000rpm is it the fuel screw or do I need a new belt? Thanks Jason
well if it's not clutching(dunno i'm on this side of the computer)then i'd pull carbs and do a good cleaning,blowing out all jets and passages,check specs then retry go from there.
how are the plugs burning?????
horkn
Yes, how do the plugs look?
allyammies
mag side is good pto side alittle dark a lot of soot on top of plugs maybe it is the caps, cleaned carbs this fall.
cajones2
Did you manually check/clean the inside of the jets? After I cleaned my carbs one time, I had a similiar problem, turned out there was some crap stuck on the inside of the jet so I used a small wire to clean it off, used a pipe cleaner with carb cleaner to address it. The problem was corrected.
allyammies
put new plug caps on took it for a spin around the bean field seems to run a lot better.Didnt think that would make a difference.
