gointhesnow
Put reverse on 2000 MM 700, 151 track, 8 tooth. Kit came with 39/23 gears. Now sled revs to 9300 rpm. Will putting the stock 21 tooth small gear with the reverse 39 gear increase or decrease revs. Stock gearing is 21/40 with 141 track. Please advise.
i belive you need to add weight to the fly weights to bring rpm down
gild
gears
Geared to high, I'm at 18/39 with reverse to not cook my clutches or belt. That is if you ride in the powder and not hardpack.
sockeyerun
Test Dummy
Think you otta scrap that heap and get a pair of skis, Oly!
