yamaha_snopro
I thinking of putting 38mm carbs form a 1995 on my 1997 sx vmax 600 which originally has 36mm carbs, my question is will the TPS plugs match up? will this mod be compatible with my sled? thanks mike
a '95(vmax?) Mike didn't have tps.
yamaha_snopro
So would i just have to disable the TPS on my 1997? How do i do that?
you can just un hook it,but it adjust mid range timing a few deg.
not sure if the performance difference would be better or worse with what your doing,dunno,try it,play with it...
