dws1700
Can anyone tell me what the compression of my 03 viper should roughly be........the dealer here dos'nt know squawt....thx
i know that one side should be lower ...by 10 15 psi belive it is the clutch side
dws1700
YA*AM*A*HEAD said:i know that one side should be lower ...by 10 15 psi belive it is the clutch side
Okay them mag and center have 123 and pto has 108 do's that seem okay or what do they come with out of the box........seems low...?
ya you sound good 120 and 110 or 115 is what i was thinking
dws1700
do's anyone know what the compression should be........?
dws1700
stock compression
stock compression 03 viper.............?
anyone know these #'s for sure.......before I tear it down
progold
The viper has varied compression ratios so they could keep the jetting 156.3 the same all across the board.
number one cylinder 130
number two cylinder 130-132
pto cylinder 120
warm sled up to operating temperature use a good screw in type compression gauge and give six pulls each wot with key turned off. (wot=wide open throtle)
hope this helps.
PROGOLD
pto cylinder 120
hope this helps.
PROGOLD
dws1700
thx.....I think i need rings........120 mag 123 ctr 105 pto and it's a little lazy
progold
Was the engine warmed up to operating temperature?,and how many miles on the sled?
dws1700
yes....I warmed it up 4 about 10 min...........it's got 6000 miles
05mtnvipermod
cant just say any number, a different compression gauge will give you a different reading. those numbers seem fine.
Skidooslayer687
u want to see the difference between all 3 not the number you get on the gauge every gauge will read different
maxpower250r
To me a compression guage is good for one thing only...to intstantly know if you have a big hole in a piston or broken rings. Heck my napa guage only shows my srx with 850 miles on it between 100-105psi across the cylinders, no worries, like skidooslayer said all guages read differently. What you need-and I forget the name of it or what forum it was where I learned to build it-is a guage that tests the amount of air leaking past the rings. Mine is a drilled out br8es plug, porcelin broken off with a fitting welded to it to attach to a length of hose with a 120psi guage, and an air chuck on the other end to hook directly to air compressor. You find absolute TDC on the cylinder you're testing, screw the hollowed out plug in there, set the air compressor to exactly 100psi and let her have the air. Heads up here because if you don't have a dial indicator to find absolute tdc the engine will spin over VIOLENTLY...I usually stick a bar in the clutch and add air GENTLY, though I'm sure a bar in the clutch is not a good idea but its how I do it. So now your putting 100psi to the rings and the guage on the contraption will read the amount of air leaking past the rings. I go by any reading over 90-92psi is o.k. below that and its time for rings. Funny thing I just used my home made guage about 3 hours ago on the SRX...98psi, 98psi, 96psi...rings are good to go! I wish I remember where the write up was on how to build this contraption but I can't. I'll look around and see if I can find it. I use the guage on all my toys, nice to know what the rings are really doing without seeing them.
O.k. its called a leak down tester...couldn't remember cause there's 2 kinds of leak down testers, the other kind is for testing your crankcase for leaks...got a home made one of those too.
dws1700
05mtnvipermod said:cant just say any number, a different compression gauge will give you a different reading. those numbers seem fine.
So u think the PTO hole being 12-15lbs lower seems ok...? the PTO plug is firing but burning black , the other 2 are tan.......it"s runnin on all 3 but a little lazey, what do u think...?
