sx trailing arm MM TRAILING ARM SAME?
kysledneck
Georgetown KY
Hello, will a 01 MM trailing arm work on a 97SX 700? Bent mine last year member here has an xtra MM arm for sale. Thank you.
it will work, but they have slightly different geometry. there is a letter stamped on the inside of the trailing arm. the 97 should have a v, the mm should be s. just check your ski alignment and spindle caster when your done.
