Hey guys i have an 02 viper. this sled runs perfect, my question though is that at around 60mph + or if you get on it real hard and let off the throttle quickly it sounds like the clutch squeels, or slips or something. I'm not sure what is going on, but it runs, reacts, and performs just like i'd expect it too in all situations. Any ideas about this squeels or slip when backing off the gas quick? Thanks for any help.
Could be brake noise. Very common on the Vipers.
is there an adjustment of the brake then?
Chain may be too tight. Go finger tight, and back off just a hair. This is easy to try.
Yes, the parking brake has adjustments as well. The main brake is a hydraulic piston disc brake, and thus self adjusts. I doubt that it is the brake though. What is commonly considered brake noise actually stems from the chaincase.
