136 rx1 skid
djanveau
timmins
Would anyone have a pic of a 136 inch RX1 skid ? I just wanna make sure the one im looking at here in town isnt missing any parts?
Also wondering if that skid would fit in a 98 srx 700?
if it is out of a rx1 it will bolt right in in stock location. if it is out of a warior where the tranfer rods attach will be back about 6" without using a tape to measure.
should look the same as your srx skid. only differences i know of is the shocks, limiters and transfer rods all being longer or spaced differently.
someone else should pipe in with more specific details but i think i have the basics covered.
hi i am the ones selling it and its only missing the rear shaft and boggie wheels ,so you can use yours out of your sled or just use shocks ,transfer rods,limiter straps to get a long travel suspension and i have all hardware
thanks dave
Will an RX1 suspension 03 go into an 02 SX Viper? any improvements expected? I have both and was thinking about putting in a 05 monoshock into the RX?
Thanks....
if its a warrior 136 skid it will not bolt up, i installed a warrior skid in mine and had to drill all new holes to bolt the thing up.
the 03 rx is the same skid as the 02 viper. the only difference is in the springs and valveing in the shocks. if that is a stock 02 viper the rx shocks will probably ride better unless the update shocks/revalve was done.
Same skid? The 02 SXV sits way low and does not have the travel as the RX1. Are you saying the skid is the same but just needs a longer travel shock?
Thanks....
they are both long travel skids/shocks.what i am saying is that the rx1 shocks will have different springs and valveing as compared to the 02 stock viper shocks.* the rx1 shock valveing will be more trail freindly.* the stock 02 viper shocks where valved very stiff from the factory.
the rx should have heavyer rate springs because the sled weighs more in a skid vs skid comparison. i might be wrong but i have not compared the part #'s to be shure.
my brother has a 02 136" viper with stock shocks and i have a 05 war. the running boards sit at about the same height front and rear.
