700sx
Just needed to know if 02 viper trailing arms will fit a 00 sxr?
^^^ What he said.
what they said ^, and after you get them on, you may have to offset the arms 1 tooth to get full range of steering.
if your buying just the arms, i have spindles from a venture that are long tube and use the stock upper crank arms that dont stretch like the viper/rx1 aluminum ones. if your going to be painting stuff, i have a rh trailing arm that is long tube as well but is venture brown color, same physical part as a viper.
also have some wider rods for that sled if your doing some painting that will make it wider. or i can sell you extensions to make it wider.
still waiting on the shock mounts for viper shocks though.
700sx
That was the other thing the shocks will i have to change those also what about the top mounting brackets for them.
