sockeyerun
Test Dummy
My 700MM is falling on it's face if I get on the gas,run the rpm's above 5000 then let off and allow the rpm's to get below 4000 and try to hit the throttle again. If I keep reving it up over 4000 it's fine and if I let the rpm's drop to idle then hit it's fine(no idle hang). It's kind of hard to explain. I have cleaned the carbs, checked all pilots ect. with magnifying glass to make sure nothings plugged. ran carb cleaner through passages. I have not added anything new to this machine for four years and it's always been right on. I always have cleaned my carbs every year with never a problem. The motor is stock except a single layer HG, reed notch, bender can. it will do this when your riding or on the stand. I have always set my pilots to 1 7/8. This problem started last year and I thought It would go away after cleaning the carbs again this year but it's still there. You really notice it if you have to slow down for a tight corner and then get back on it. I'm pulling the carbs and go through everthing again, just looking for suggestions on what I could be missing. Thanks, hope this makes sense. Soc
