piped viper bog
yammyhamer408
Espanola
we got about 2 feet of snow now and some places 3 i whent out riding today and the sled would run good WOT then bog the come back on th raod any time i would get in to the powder or deep snow it would bog out realy bad and almost stop runing. and sujections on whats going on with it.
could be alots of stuff ... bad cap sparkplug ,pipe could be plug up with snow in deep snow,could be fuel screw to mutch open and it bug under big load could be alots of things secondary to loose and .......................... need to give more info
could be that your carbs are gummed up. Had same problem. You let off the throttle and it bogs down. Does it idle at proper rpm? or do you have to be on the gas?
i took off the pipes put it all back to stock it was rning good today and it did it again only some times on the road. it wont take any hard thratull now would broken reed pellets caus the bog at high rpm after 5000 rpm its starts to die then i give it a shout it will rev to 9000 rmp and then bog and drop to about 5000rpm. its werid.
thanks for all the help i checked everthing u guys sayd to and it blew up on me this moring on the way to school i will keep u guys posted on the rebild thanks for the help
