Corey9965
When I start my SRX the PTO cylinder Valve is leaking some oil onto the pipe. Is it a bad gasket or what?
mopar1rules
yep, bad oil seal and/or bad gaskets. maybe even just loose bolts?
Corey9965
I suppose I will change all the gaskets next week when I try my hand at cleaning the P- Valves for my first time. Is the oil seal a bit@# to change? This is my first Power Valved Monster and I want everything to be right when the trails open.
no easy to change ...easy to clean and adjust also ....well the cleaning part aint so easy takes alot of scrubbing and soaking ....aircraft stripper seems to loosen the carbon off the valves ...just dont scrubb off the coating on the valve
mopar1rules
the cleaning is easy for me.....i use a scotch pad wheel on a 90deg air grinder. takes the stuff right off, but is soft enough to leave the coating alone.
http://www.totallyamaha.net/forums/showpost.php?p=350913&postcount=3Corey9965 said:When I start my SRX the PTO cylinder Valve is leaking some oil onto the pipe. Is it a bad gasket or what?
