Viper-Rules!
Okay guys. I ran the sled today at 10 F and it ran like a top. I always have my carb heaters on, since the dial is a real bear to turn. When I ran it at the end of the season, I had a hard time starting it when it was warm and it wouldn't idle that well. Now that it is cold it is fine again? would the carb heaters effect engine performance like that in mild weather?
Yamidude59
your inbox is full clear it! i added you on msn.
Unless she's cold out or your bustin powder leave 'em
off,not needed..
off,not needed..
just make it a little bit richer when warm out, it sends the warmed coolant thru the carbs and warms up the air incoming, nothing drastic.
