Corey9965
I just took the YPV cover off of the servo and I found that 1 of my PV cables (Mag Cyl) is not connected like the other 2. The cable was just "hangin" out in the box.
Now I have yet to ride this sled being that I purchased it in May 08. Could this have caused any lasting problems or should I just clean them sync them and ride?
viperino
need to inspect the power valves to find out. Will probably find that mag side valve is stuck. Wouldnt have caused any permanent problems in the motor. Inspect, clean a readjust valves.
You likely pulled the cable through the end of the valve. Take the 4 allen screws off that valve and check it out. The valve may be stuck in the engine as mentioned above.
