phazerBILL
Hi, I just put new exaust gaskets in my 1999 Vmax 500, I was wondering what do you torque the 4 exaust bolts on the y pipe that go into the cylinder to? I dont want them to twist off but I dont want them to come lose and oil spit all over and lean out and blow up... I cant seem to find any torque specs, and the TY Tech chart is kinda confusing.... I would like any other torques to check while im at it.... Thanks!
22 ft.lb's
post up bill if you need any thing more...
phazerBILL
Wow Thanks!^ Thought it would be around 20's. Will your sled lean out if there is an exaust leak? How do you check or should I just check the plugs...
if you have a leak you'll know it, oil every where under/around the pipe, yes could run lean too but it would have to be a bigger leak.
