edge suspension in viper
racerguy
land of 10000 lakes
Im a little confussed on the measurments I got the ones from jbshocks and was reading on here but not sure if I need to move the front back to 9 inches or drop the hole skid down 1 inch . or if the measurments are correct thanks for any help :letitsnow
i put an edge skid in my 01 srx it was a really easy job but i forget the measurements. i will check for you tommorrow for you. it made a world of difference. what shocks do you have for it?
I put a edge in mine and we moved it back about a 1/2" so the front bolts would not hit the steering loop down by the foot wells. If you lay it out per jbshocks the front holes landed right where that support is, so we moved the whole templete back a 1/2" and it went right in. I just made sure the rear axel was sucked all the way in when we installed it. If you do a search of my name you should get some pics and stuff about the install.
I think I would like to do this to my '01 SRX, but I have a couple of questions. What year skid should I look for? Where do I look, and what are you guys paying for these?
I iinstalled a 03 edge in a xtc it was a simple job.I also used jb shocks specs.
ok so go off JB shocks specs, but go back 1/2 inch so you clear the stearing support, and drop the rear 1 inch for more clearance, sounds good thanks to all for your help. :winterrul
Hvac Guy, I found mine in the summer a year ago for $250 and sold my proaction for $175. It was an 05 edge and the colors of that 05 edge are sliver and black and it looks good under the sled.
Thanks, I guess summer would be the best time to get a good price. I found one from an '01 locally for $450!
