front suspension shaft is seized
zooman
Cameron Ontario
Hey guys I have a 92 Phazer and I have the suspension right out of the machine.
The problem I have is the the front axle shaft on the suspension won't come out of the tube. It's the shaft that bolts go through the front of the tunnel onto this shaft. I may be crazy but I am pretty sure this shaft should come out. I have been soaking it in rust killing spray for a few days and it still won't budge. Am I right thinking this shaft should come out?
Do you guys have any tips on getting this shaft out? I have a torch set up but I just ran out of oxygen.
What would you guys do.
Thanks guys,
Matt
Your Shaft Is Siezed
The shaft is aluminum , the arm is steel , disalike metals . Put a long bolt in threads as far as you can , heat up shaft and bash it out .
Yeah, I just redid my suspension. I had to torch everything apart and replace with new parts. The new bolts I covered in antiseize before reassembling.
