ottawaair
Anybody out there running thier throttle so it a pull style. Like if you flipped it over & the kill switch was on the bottom. Is there a kit to do this the right way?
If you find a kit take a picture of and post I am interested in the exact system.
i just run the perch fairly loose(minimal effort to twist), this allows me to accomplish two things: first and foremost rotate to change thumb location for sidehilling and thumb fatigue. you can rotate on the fly and save cramps. secondly and almost as important, if you bail off or roll over the flipper is not rigid and will give(rotate) verses snapping off. damn things are expensive to replace. saves kill switches too.
ottawaair
that's not a bad idea, it's a little easier to control in rough stuff with it in thumb side.
