OnDaTrail
When adding studs to a track, how many tunnel protectors to you need to install? Is it one for each row of studs or just a pair. I've never done it before. This is for an '01 Phazer so no heat exchangers involved and I'm planning 96 studs, 1.25" on the 1" lug stock track. Thanks.
Tunnel protectors run in-line with the track windows(square holes in track) , so you need two, one for each side, running the length of of the tunnel. You may also want to add some protection at the front of the tunnel where there would normally be a heat exchanger.
Hears a pic of a tunnel with protectors.
OnDaTrail
OK, that makes sense. Thanks.
