cajones2
I have hauck hushers for the ole 600 sx here. I believe they are the same ones as the simmonscpr pipes (but from hauck). In the past when i have had bender pipes, they drop down maybe 1/2" - 3/4" and had a nice little "tray" to keep them in place too. I bought these pipes used and was sure if I got all the parts, or if this is normal? I'd hate to damage them as they look like they stick out quite a ways....any insight would be greatly appreciated.
Thanks!
Craig
Thanks!
Craig
blueblooded
Wow,those wouldnt last long on the trails i ride around here.I'd try and pull those up or shorten them.
cajones2
The pipes themselves fit in there pretty tight so I don't know how much play I have to pull them up which would be the ideal case. I am thinking I'll have to cut them although I am feeling a little hesitant in doing that. Why can't it just all go together perfectly?
bufalobob
you're missing the black rubber gasket that goes in the belly pan exit hole. put it in & then reinsert the silencers. that may solve your dilemma.
bob
bob
cajones2
hmmmm....I think they must be MIA. I'll see what I can find. I was hoping these pipes would have come with that nice flange that the bender pipes have. My old 94 vmax 600 had a nice "tray" the flange sat in and it bolted to the chaincase, a pretty nice design.
VenomMod
I bought AAEN's from Hauck (I know different pipes), but they stuck down the same way out of the belly pan. I ended up taking a bit off of each to cut them even with each other with about 3/4" below the belly pan.
cajones2
Did you have any kind of a base that they sat in or do they just individually exit the exhaust hole in the belly pan?
srxeater
If you can't re-positoin them to fit correctly, cutting them should not be a concern. If they were stingers i'd say no, don't cut them but with silencers I don't think it will matter.
cajones2
I am definitely missing that piece that rivets to the bottom of the pan. I'll check into that, as well as the missing gasket...then I will trim as required. Does anyone have this flange out there by chance? Worth a try. ;-)
VenomMod
cajones2 said:Did you have any kind of a base that they sat in or do they just individually exit the exhaust hole in the belly pan?
I didn't have a base to set them in. I just reused the stock rubber gasket (according to the instructions). I was a pain dealing with Hauck, because they gave me the wrong directions (jetting and set up). So I had to give AAEN (maker of my pipes) a call to get everything I needed.
