Larryautotruck
Hey Guys- HELP!!
I installed used Ace M10 suspension in my 2005 RX1, it came complete with gauge, controller, regulator rectifier & wiring. I obtained wiring diagram from local Polaris dealer, wired everthing up but I have 1 problem. The regulator rectifier has three wires, #1 red goes to controller, #2 yellow is AC in, #3 is ground.
How can I get AC voltage from my Rx1. I understand the stator produces AC voltage- three white wires to rectifier under tool box, but how to hook up. Also what voltage is going to regulator rectifier.
Does the ACE M10 suspension motor work on AC or DC voltage. If it is DC, could I just eliminate the regulator rectifier supplied with suspension & hook up 12v to #1 red to controller?
Any help is appreciated
LARRY
LARRY
Larryautotruck
Ace M10 in 05 RX
I installed this used suspension which came with a voltage regulator rectifier. I wired up according to diagram, did't work. After asking for help everywhere I could think of in Canada & USA, I hooked up direct 12dc to motor and it worked. I then decided to eliminate the voltage regulator rectifier from the circuit, installed inline fuse, it works. Problem is no gauge- I'll get it fiqured out & let you know, unless anyone has any info.
Larry
Larry
