Warrior SX
I bought a set of Power Inc. pipes for my 99 600 SX. I was wondering if anyone knows what size jets I should be running. I didn't get any jetting specs with these. Thanks for any help.
Turk will know for sure
End dumps or Center?
Warrior SX
Center, the pipes come to a point and the stingers come out of the bottom.
mod-it
Elevation will help them with a recommendation.
Also what temp you want to jet for, -20 to 0, 0 to 20, etc.
Warrior SX
Around 1500 ft, and jetting for like 15 degrees.
If the sled burns good now, Just Jet up 2 sizes. That should be plenty.
Warrior SX
I moved up to 137.5 pto and center and a 140 mag. It runs good wot, but there is a slight dead spot if i cruise around slow then crack it.
What pilots did you put in? Did you adjust the c-clip for mid range? What's stock jetting?
