Probably didn't get the pilot jets cleaned out well enough. I've never been able to get gummed up pilots clean by spraying cleaner or air through them, I take a bread tie wire or cut one off a wire brush and run through them, spray cleaner, repeat...
Its kinda hard to see through them, but you should be able to see a tiny, ROUND hole through them when they're clean. A quick way to test if its the pilots is to flip the choke on for a second and see if it helps it run better from idle.
