quick question about the powervavle cables/servo
djdarkmunk
maine
ok so i took out my power valves. and un hooked the cables to the servo is it ok to rotate the servo manually to hook the cables back up will it go back to its original postilion. im kinda unclear on this step. thanks a lot you guys are lots of help
Yes it is fine to Rotate it by hand, it will go home once the sled is started. you will need to make proper p/v adjustments though when you are finished. i'm assuming you are aware of that already.
Joe
