ViperGeek
guys, i just cant fine were i placed those screws, does anyone know the replacement size for them so i can pick some up at the hardware store, Its a 98 yamaha SRX600........ hope someone knows....
servo valve ?? servo cover screws? or the 4 powervalve housing bolts?
ViperGeek
YA*AM*A*HEAD said:servo valve ?? servo cover screws? or the 4 powervalve housing bolts?
the 4 housing screws....from the servo cover
Yamidude59
think about what your saying...."the 4 housing screws from teh servo cover" hmm....? wrong terms! your talkin about the aluminum block that holds the housing to the engine.
ViperGeek
Yamidude59 said:think about what your saying...."the 4 housing screws from teh servo cover" hmm....? wrong terms! your talkin about the aluminum block that holds the housing to the engine.
These 3 screws, sorry i was incorrect and unclear..
Yamidude59
yamaha part # for those screws are 98517-05010-00 they are $2.37(with Wi tax) for 3 from yamaha
ViperGeek
Yamidude59 said:yamaha part # for those screws are 98517-05010-00 they are $2.37(with Wi tax) for 3 from yamaha
The dealer has none right now, do you know the size???
NY AttakGT
Save yourself some money and get the same allen head screws from Home Depot or Lowes. They are metric, but not sure of the size right now. $2.37 from the stealer?...errrrr, I mean dealer. I've replaced those screws, along with some of the power valve housing screws, as well. All from Home Depot on the cheap!!
--Steve (O.C.)
--Steve (O.C.)
ViperGeek
NY AttakGT said:Save yourself some money and get the same allen head screws from Home Depot or Lowes. They are metric, but not sure of the size right now. $2.37 from the stealer?...errrrr, I mean dealer. I've replaced those screws, along with some of the power valve housing screws, as well. All from Home Depot on the cheap!!
--Steve (O.C.)
Stealer is coorrect, I am going to replaace them with allen head screw, I have them at work, I didn't want to remove the sero to match the threads thought someoone knew, thanks
5mm 1.50 pitch i think.
ViperGeek
hanker37 said:5mm 1.50 pitch i think.
measuring with a caliper, that might be it
