Clutch question for Turk
Squeeze Play
Rogers, MN
Hello Turk. I read your clutch specs for the 02 & 03 viper. I have an 04 viper and I am assuming the spec will still work, please correct me if I am wrong. You mentioned the 53/43 helix and the yamaha green secondary spring. Do you twist the spring at 6 and 1 for the stock 70 degree tension?
Thanks Turk!
I would use the stock red at 80 degree wrap. We found that last year the red worked very well at 80 or run the green at 60.
04 viper with 53/43 helix
Where do you see an improvment with this set up,bottom,mid and top end?
Will this set up kill some top end speed?
Thanks.
blueblooded said:
Turk,where are you?
He has a job that involves him traveling for a week or more at a time very frequently. He's probably out of town.
