7 tooth drivers
justheman80
Idaho
I need to find a source where i can get 7 tooth drivers 2.52 pitch for my yamaha exciter. Western Power Sports has them on back order and does not know when a shipment will be coming in. Does anyone know of a place that would have them?
Did you try to other mail order houses. I guess I should call them online supply houses.
Dennis Kirk
JR Graham
High Performance Engineering
ShadeTree
Spanky's
Yup I just found out the same info yesterday........ :eek: :confused: :eek:
Come to think of it, I think Yamaha makes them also. I have a set on my Phazer and I believe they are stamped YAMAHA
a company that i was going to buy the WPS drivers from said they could get factory drivers for me at $150.00 a driver, I said no thanks.
I have called many places trying to order the correct drive sprockets, but i am getting different stories on what size of sprockets fit my drive shaft on my Exciter. Some say it is .950 inches, others say it is .995 inches and I am also getting 25mm which is .984 inches.
What size of hex drive sprockets will fit on my Exciter?
I am positive it is 25 mm let me know if you can where you find them. Thanks. :yrules:
