I was wondering if anyone had popped the clam shells off of their stock pipes and put new insulation in to help keep the heat in?I would love to be able to send mine out for ceramic coating and eliminate the need for the shells but that'll have to wait.What type of insulating material did you use and how well did it hold up?Would plain old fiberglass insulation work or should I look for something else?
Yamidude59
Its still a good idea to put the heat shields back on even if you get the pipes coated, gets you even more heat insulation.
