could someone lead me in the right direction of how to adjust the track on a 97 vmax sx 700? Do you just losen the axel that goes through the bogie wheels and then back the screws out on the back of the skid?
yup,right on...
are you trying to adjust deflection????
mod-it
Yes, that's how you adjust. Count your turns on each side and try to keep them even. After adjusting and tightening the axle back up, run it on a stand to make sure there is the same amount showing on each side so you know they are even. Backing the bolts out on the skid will loosen it.
backing the adjusting bolts out will tigthen or loosen the track?
loosen
