blkmax600
Hey Guys, I removed my carbs off of my 700 SXR, they are the heated carbs, my question is do I have to bleed the coolant system when I reinstall the carbs? I did quickly plug the coolant lines when I removed them so I lost very little fluid.
I usually remove my carb rack at the end of the season, clean it up and put it on a shelf for the summer, I pluged the coolant lines and when I'm ready to install them I just put them back in.....without bleeding, If you are worry about airpocket in your system, just raise the end of the sled up in the air a couple feet and open the little srewcap on the rear cooler, that would let the air escape.....Sorry if it got to be to long, I did not took my medicine today.....
Nick
Nick
just run it it will be fine
blkmax600
maxdlx said:just run it it will be fine
That is what I was hoping to hear!!
