98 srx suspension swap question
djanveau
timmins
Just wondering if anyone has put a 2003 rx1 136 suspension into a 98 srx?
Im not sure if i should use the srx or rx1 H or W arm if thats what its called? Also wondering if theres a template for relocation or does it just bolt in? Also do i need drop down brackets for the rear?
i put an 05 warrior skid in my 01 srx, there is no template, you will need the rear drop brackets, the front holes bolt up and rear middle and rear holes you have to drill, i measured the warrior and a mm to find where to drill my holes. i think i drilled wrong because it was a real b**** to bolt the rear and center up because the load from the shock. but it does perform well.
