Speedo on '88 Inviter
nytoy
rochester, NY
Anyone have an idea how the speedo works on an 88 inviter? I assume its cable driven? Currently it doesn't work, thanks.
The speedo is cable driven from the right side of drive axle. Theres a angle drive with cable connected , you can unscrew cable and try to spin inner cable by hand and watch meter for movement. If it works then unbolt angle drive from tunnel and theres a small 3" connector key from shaft to angle drive that could be broke. They are replacable and cheap. Sometimes hard to remove the pieces from axle and angle drive,I use a small sharp pick type tool to kind of hook piece to pull it out. If the meter doesn't work when spinning main cable by hand ,then main cable is probably broke. Hope this helps . Dennis
